et streets with stock 16's
Ive got some et streets mounted on stock 16's with tubes. Im twisting the tubes up so that I cant get to the valve stems what are yall doing to keep the tires from spinning on the wheels?
You are spinning the wheel in the tire. Sometimes that is caused by the tire shop using lube under the beed, don't let them use that crap. I glue the beeds and don't run the tubes. If you're running really low air psi you might have to screw the tire to the wheel. Slummit sells the screw kit.
what do you use to glue the beads? they suggested super glue.
Local tire place puts baby powder on tubes, and glues the slick to the rim with some black urethane looking stuff.
3M weatherstrip adhesive, colloquially referred to as gorilla snot, is now available in black.
Thanks guys ill try that tomorrow and hopefully that will fix it:cheers:
Originally Posted by MikeGyver
(Post 4669699)
This^^^ I use this on my S10 |
