Engine light
Old Jan 23, 2012 | 05:49 PM
Go5.3tt06's Avatar
Default Engine light
Hey. My 2006 Silverado got light. Went to auto zone scan. It's show
Which exactly it is. O2 sensor? I know that Nelson program my PCM to delete rear o2 cause I ran a catless. It been fine for 2 yrs. now happen can you help me which one
Old Jan 23, 2012 | 06:38 PM
Slammed96's Avatar
It is being triggered through the upstream sensors. I would check to see your MAF is reading correctly, and also check for any vacuum leaks or potential causes of under fueling.
Old Jan 23, 2012 | 06:42 PM
Suburbazine's Avatar
What's the code that they got to get that definition? P0171 and P0174? What other conditions are present when that code is active? What are the O2S reading? Etc.
The Autozone printout is more or less designed into getting you to purchase 120 dollars worth of stuff you don't actually need but actually can't return.
Old Jan 23, 2012 | 07:59 PM
Go5.3tt06's Avatar
let me check and will right back to yall
Old Jan 24, 2012 | 04:24 PM
Go5.3tt06's Avatar
P0175 bank 2 too rich*
P0172 bank 1 too rich
Which one I need know that needs to replace front or rear. But Nelson program my PCM cover for rear o2 I think. Pls let me know.
Old Jan 24, 2012 | 09:31 PM
Both sides rich like that is most likely a bad mass air flow meter. Try cleaning it with some carburetor cleaner or mass air flow sensor cleaner if you can find it.
There is a chance that a table is not programmed correctly in the tune but I would suspect the MAF before the tune at this point. Oxygen sensors are not likely to be the culprit as they usually fail lean instead of rich.
Old Jan 25, 2012 | 08:10 AM
Go5.3tt06's Avatar
Thought if I clean maf will mess up?
Old Jan 25, 2012 | 12:02 PM
06SilverBirch's Avatar
formerly 98wytebord (3-14-2012)
No it wont mess it up they sell cleaner just for that at Autozone etc.
Old Jan 25, 2012 | 12:07 PM
00ChevyScott's Avatar
Wearin' da big hat
Old Jan 25, 2012 | 03:51 PM
Go5.3tt06's Avatar
[QUOTE=00ChevyScott;4854273][/QUOTE
Thank you. I will do.
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
