View Poll Results: E-fans:What brand & why?
'05 E-fans
61.54%
LT1 fans from?
3.85%
LS1 fans from?
26.92%
Spal
0%
Another aftermarket brand
7.69%
Voters: 26. You may not vote on this poll
E-fans? Which 1 did u go w/. & why?
Old Oct 18, 2009 | 07:57 PM
  #21
SilverDog's Avatar
Here is another modified schematic with how to wire in the lights and switches.
Hit low switch and both fans come on low.
Hit high switch and right fan comes on high.
Hit both switches and both fans come on high.
LEDs work with manual switches and the PCM.
Old Oct 18, 2009 | 09:46 PM
  #22
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
ls1 fans are the best bang for the buck IMO
Old Oct 18, 2009 | 09:49 PM
  #23
budhayes3's Avatar
PT's Slowest Truck
Well you know which fans I'm a fan of Tom, but many have had great results with the LS1 fans also, and they are a lot cheaper than my setup was. As I mentioned, besides the fans being bigger, I also like the added cooling capacity of the 34" rad...here's how much my setup breaks down to IIRC...
New 05 take-off efans: $200 shipped
New aftermarket 34" radiator: $265 (can't remember about shipping)
Nelson fan harness: $100 shipped (yea you can make your own, but this thing really looks about as factory as aftermarket gets)
PCM tuning will vary...since you have HPTuners (did I get that right?), this will be free for you
Other variables include new coolant, t-stat...I also got a 145 amp alternator, but not because of the efans, just because...
My fans appear to be setup to come on at 177 and off at 170 (according to my scan tool), and my truck consistently runs around 175ish
Old Oct 18, 2009 | 09:58 PM
  #24
GMCtrk's Avatar
well, I've been an opponent to the ls1 fans, but i gave in. I'm sick of looking at the clutch fan in the engine bay. $55 shipped for the fans and $89 for the blackbear harness. So I've got roughly $145 in the setup.
Old Oct 18, 2009 | 09:59 PM
  #25
Mangled03gmc's Avatar
Baltimore Whore
Tom
Like stated the 05 fanss are nice if you up to the new radi, are def more$$
Here is mine, seriously look factory
Old Oct 18, 2009 | 10:00 PM
  #26
GMCtrk's Avatar
How'd you mount those fans to the radiator John? Engine bay looks so clean too
Old Oct 18, 2009 | 10:04 PM
  #27
dirt track racer 81's Avatar
I got my ls1 fans for free, they been on fire i have two relays that turn them on. it was set up with a thermostat that was in the radiator but i took it off. cant get any more simpler than 2 zip ties haha..
Old Oct 18, 2009 | 10:05 PM
  #28
Baltimore Whore
Thanks
I like to keep **** clean and simple..I used the lil tabs that go through the radi for mount trans coolers and all.. Used 2 to gold it in, it holds it damn good, is super clean.. Also the ls1 fans sit right down on top of the trucks core support, so they are just holding it up to the radi.. I know they work cause I have seen a fair share of 140 mph blasts..
Old Oct 18, 2009 | 10:06 PM
  #29
GMCtrk's Avatar
Thanks
I dont understand. Do you have any pictorals or explain it better. thanks. I like how yours is super clean with no metal mounting bars.
Old Oct 18, 2009 | 10:12 PM
  #30
Baltimore Whore
These tabs.. Work perfect If you take your stock shroud off, look at how much sticks out the bottom of the radi. The core support lets the fans sit right on top of it, then these tabs hold it to the radi
http://www.jerrybickel.com/images/jb...-Fan%20Big.jpg
