View Poll Results: E-fans:What brand & why?
'05 E-fans
61.54%
LT1 fans from?
3.85%
LS1 fans from?
26.92%
Spal
0%
Another aftermarket brand
7.69%
Voters: 26. You may not vote on this poll
E-fans? Which 1 did u go w/. & why?
Old Oct 17, 2009 | 03:07 PM
Mangled03gmc's Avatar
Baltimore Whore
Ls1.. They are cheap and fit the stock radi almost as well as a factory would. They are, will cool just as good as the bigger ones, no need to change the bigger radi for them.. ls1 fans are the same Camaro-firebird-vette
Fans off ebay 80 bucks
Nelson harness 75 bucks
Old Oct 17, 2009 | 03:24 PM
fastnblu's Avatar
John, how'd u score a Nelson w/h for only $75? Ebay?
Old Oct 17, 2009 | 03:42 PM
Baltimore Whore
Old Oct 17, 2009 | 03:58 PM
fastnblu's Avatar
That doesn't tell me ****.
Old Oct 17, 2009 | 04:26 PM
Baltimore Whore
Find a set of used fans, go to blackbearperformacne, get one of justins harnesses. He wasn't doing them when I needed it... His is 7x some bucks...
Old Oct 18, 2009 | 11:40 AM
fastnblu's Avatar
For those that have tuned their own, & obviously know how to better than me, what temps on/off did u set fans at?
Anybody have their tables for on/off that they used? Whippled496 had some IIRC. Where should Fan1 turn on/off in relation to Fan2?
I know if ya do it @ wrong temps, they'll run constantly.
I'll be using HPT if that helps.
I found a 160* T-stat w/. a lil searchin at a good price. I'll be snaggin that in the next 2 days.
Last edited by fastnblu; Oct 18, 2009 at 04:08 PM. Reason: Tables for Fan1 vs Fan2
Old Oct 18, 2009 | 12:47 PM
SilverDog's Avatar
I went with the LS1 fans. I got mine off of ebay for around 120. It came off of a 2002 SS Camaro with low miles. I made my own harness for 30-45, but that includes 2 manual switches and 2 indicator lights in the cab. If you have any general electrical knowledge and have time then making a harness is easy. Go with the 2 pin option when it comes to controlling your fans.
Old Oct 18, 2009 | 04:13 PM
fastnblu's Avatar
You've got a real sano install there!
SilverDog, I wouldn't where to begin on makin a new harness. What gauge, length, colors of wire? Got pics of those manual switches? As for indicator lites, I'm envisioning some rocker switches, right?
Explain 2 pin option?
Do I need relays of some kind?
Sorry for all the questions, but if I can make my own, it'd be great since I don't have a lot of $.
Old Oct 18, 2009 | 07:09 PM
SilverDog's Avatar
I don't want to clutter your thread up with pictures so here is a small writeup I did.
https://www.performancetrucks.net/fo...d.php?t=437058
I'm not a fan of rocker switches, I went with something alittle more stock.
Color of the wire doesn't matter but it helps with identification. When it comes to gauge go with something that can handle the proper amperage(10amp trigger, 40amp power).
Old Oct 18, 2009 | 07:12 PM
GMCtrk's Avatar
You care to make me 2 of those brackets?
