E-Fan Temp Sensor
Old Jan 17, 2012 | 09:33 PM
lady3bglover's Avatar
Default E-Fan Temp Sensor
Recently, I upgraded from 5.3 to 6.0. Along with that I've swapped the '05 e-fans to Derale 4000 Cfm dual fans.
I would like to step away from using the sensor that's linked to the ECM for controlling the on/off of the e-fans, and use a secondary source. I have also chosen NOT to use any sensor that would make me push a hole through my radiator.
There is a bored hole, at the end of the passenger side headers, that has a very unfortunate size which is NOT applicable to ANYTHING that I could possibly use it for! Am I a little bent? YES!!!
Do you see that stupid plug, it's bore to a 12.175mm!?!?!
I can't find an adapter for the stupid thing...
Anyone a machinist?
Old Jan 17, 2012 | 10:03 PM
Ferocity02's Avatar
I seem to recall that it was a fairly standard size, and that some people put their aftermarket temp sender units there. I have no idea the size though.
Old Jan 17, 2012 | 10:15 PM
I can tell you the size is 12.175mm
Old Jan 18, 2012 | 08:09 AM
robbyredneck's Avatar
LS1 Water Temperature Sender Adapter - Speedway Motors, America's Oldest Speed Shop
this is the first one i found . i think i got mine from summit. real standard item. some guys retap the head.
Old Jan 18, 2012 | 05:47 PM
Thank you.... Much appreciated.
Lisa
Old Jan 18, 2012 | 06:12 PM
BlackGMC's Avatar
Resident Retard
Whats wrong with the ecm contriling the fans???
Old Jan 18, 2012 | 06:43 PM
I changed the fans from the '05s to 4000cfm Derale Duals. I was using the Nelson harness and the fans started short cycling, which never happened with the 05's.
Both the harness and the fans were getting teerd and b/c I have a new set up, I went with new fans. I wanted to take a diff route and use another one of the engine bungs specifically for a temp sensor for the fans.
If you see that pic that I posted Corey...that damn tap is 12 x 1.75, WTF!! And the sensors thread is 3/8th British. I sure hope that I'm making sense.
Pimpinpete
43
Dec 22, 2017 08:13 AM
trevorh1
Sep 27, 2015 08:47 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
kmcn47
Sep 17, 2015 01:12 AM
