Few questions help guys
So I have the opporitunity to maybe build a little toy.. A buddie of mine has a 2000 RCSB, the truck is a V-6, 5 speed. I also found a good buy on a almost complete LQ4. Block and most accesories..
So here are the questions... What all will I need to buy WIRING wise to put the 6.0 in the truck? Also thought about a T-56 so what is needed there? Or if I go with a auto same question? Im sure I will have a few more..
THANKS FOR ANY HELP YOU GUYS CAN SEND MY WAY.. I havnt bought either one of these just doing some brain storming....
I have no experience with this or a V6 for that matter, but I would guess that you will end up needing to buy a complete harness and PCM from a LS truck with a 5 speed. You can pick used harnesses up for $250-400 usually, just make sure its uncut. You could easily swap to a 4l80 this way as well.
lxcoupe
Jul 21, 2015 02:12 AM
