E-fan over ride..
Tap into the wire that goes to the PCM and run a wire with a switch to ground, then you can ground the wire just like the PCM does and the fans will operate on low at your command. Depending on how your ac/high fans are wired, you can either run a second wire with a second switch for high fan operation (you will need a diode in the wire so that you don't engage the compressor clutch when you flip the switch), then you can choose low or high when you want the fans on.
If its an 05 you should have the two pin harness, in which case, find the blue and green wires connected to the pcm and tap into them and install a 3 position DPDT switch like this
up is low, middle is auto, down is high
lycominghunter
26
Sep 25, 2015 07:50 AM
