do you have a 07-08 Denali Serria with 6.2?
Old Aug 25, 2008 | 01:43 AM
nickd907's Avatar
Registered User
Default do you have a 07-08 Denali Serria with 6.2?
If so, tell me what you think of it, be honest.
How is the aftermarket support for the 6.2?
Does the tranny and rear end hold up hell with simple bolt ons like programer, intake exhaust?
What kind of mileage do you get?
Thanks in advance
Old Aug 25, 2008 | 03:26 PM
nickd907's Avatar
Registered User
Anyone?
Does anyone know another forum i could try?
Old Aug 25, 2008 | 05:08 PM
Bo185's Avatar
Thanks in advance
The 6.2L is just basically like the other Gen III/IV V8's. Other than cams which they now make VVT cams as well or the intake.
The transmission is alot more stout than the 4l60 you won't brake it with bolt ons and a tune. The rear which should be (not 100% sure) the 14 bolt SF.
Old Aug 25, 2008 | 05:19 PM
GMCtrk's Avatar
I've heard they get really bad mileage. But I mean, what do you expect from a 400HP engine in a 5500 lb vehicle?
Old Aug 25, 2008 | 08:22 PM
v8
17,16,15,14,13,12,11 Drvr
The one I rode in and tuned made me allmost go out and buy one hahhaa. Ran low 14's with just a tune in high 80* weather.
Old Aug 26, 2008 | 02:02 PM
James B.'s Avatar
The 6.2 is strong. It has a wider range of power (torque) available than a 5.3 or 6.0, not to mention greater horsepower. The transmission is a 6L80-E, it's stronger but feels a lot different than a 4L60-E. Overdrive is a very high gear ratio and combined with the high axle gearing these trucks are set up with you get very low highway RPM. There's not much torque available at those engine speeds so just about any pressing of the throttle leads to a downshift or two. We're all trained to try to avoid downshifts when we need to accellerate lightly, but on these trucks it's necessary and how they work. you'll get used to it. The 6.2L SUVs are all full-time AWD, so the rear end is just a 10-bolt since it's not technically supposed to ever see all the engine torque itself. If you want a 400HP SUV and are worried about fuel economy, ask yourself which you want more, because you can't have both.
Old Aug 26, 2008 | 04:55 PM
nickd907's Avatar
Registered User
Dont know I missed this posts...
I think I am learning more toward the awd seirra the the yukon.
With the new 6 speed tranny, kick down or down shifts are "ok" to an exstent? Unlike my ram, kick down at high speed is a big no no
Old Aug 26, 2008 | 08:14 PM
Bo185's Avatar
They only come with 3.42 gears, so with the overdrives it needs to kick down. You can get the trucks in 2wd or AWD. Also, for 09 you can get an LTZ Chevrolet silverado crew cab with the 6.2L as well
Old Aug 26, 2008 | 08:23 PM
nickd907's Avatar
Registered User
Is the 6 speed on the 09 as well, what are the release date for the 09s?
Old Aug 26, 2008 | 08:28 PM
Bo185's Avatar
Yes. Even some of the 5.3L in the crewcabs get the 6sp as well. Sept. I think?
