Dimming headlights???
Old Jun 2, 2005 | 11:56 PM
bodyguard6799's Avatar
Default Dimming headlights???
I have LS-1 fans w/ Nelson harness, ASP underdrive crank and overdrive alternator pulleys, a 130A alt and a yellow top Optima battery and I noticed that when I'm going down the road @ night with the A/C on my lights will flicker and the volt meter will drop a little just for a second and then go back to normal (it also does it durring the day but I dont notice it like @ night). It will only do this with the A/C on so I figure its got to be when it cycles. I have also upgraded my alt to dist block and block to chassis wires but didnt get a chance to upgrade my battery to ground wire. Is this normal or is something wrong?? THANKS!!
Old Jun 3, 2005 | 02:24 AM
thunder550's Avatar
High on diesel fumes
My 200 amp alt drops from 14.2 to low 13's when the fans kick on high, then comes back up to 13.8 or so. I would think that as long as your voltage doesn't flutter you're probably ok.
You might want to try connecting a wire directly from the alt to battery +, battery - directly to ground, and engine block directly to ground as well....don't worry about the dist block, bypass it completely. It's connected to the battery cable anyway.
Old Jun 6, 2005 | 10:52 AM
What about upgrading the battery to chassis ground, would that help?? Also do you think upgrading to a newer 145A alt vs. the 130A alt I have on there now would make any difference?? THANKS!!
Old Jun 6, 2005 | 12:29 PM
thunder550's Avatar
It definitely can't hurt to upgrade the battery to chassis ground, and it also can't hurt to upgrade to a 145 amp alt. I don't know how much of a difference you will notice from 130 to 145, but I noticed a huge difference from 105 to 200.
someotherguy
Nov 8, 2017 06:46 PM
dantheman1540
Feb 24, 2016 09:56 PM
kmcn47
Sep 17, 2015 01:12 AM
the owl
Sep 4, 2015 04:09 PM
Blackrat48
Jul 11, 2015 12:36 PM
