Difference in 99-02 silverados
Old 12-15-2011, 08:56 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by _zebra
also, you can't disable the automatic headlights in a 99.
i believe the 99-00 coil packs were different as well as the engine cover
The top cover was square on the 99-00 and rounded on the 01-up
Coil packs had nothing to do with year. I have seen 3 different versions on all years.
How ever valve covers did change do to the PCV system routing.
Old 12-15-2011, 08:59 PM
1FastBrick's Avatar
Not sure on the head lights??? if you push the dome light button in and out 3x its supposed to bypass and work of the switch.
Old 12-15-2011, 09:04 PM
makes children cry
_zebra's Avatar
oh really? they mixed coils. reckon i just got a good pick with the 5.3 i bought
that's the 00-02. 99 has no override - i had to take my dash apart to disable mine
Old 12-15-2011, 09:08 PM
1FastBrick's Avatar
Some had round coils and I believe there were 2 different version of the squared coils.
what did you have modify for the lights???
Old 12-15-2011, 10:07 PM
brandon6.0's Avatar
my brother has a 99 and i have a 00. He cant override his lights but i can.
Old 12-16-2011, 11:53 AM
makes children cry
_zebra's Avatar
you have to get to the photoresistor (that little black bulb by the windshield), and unplug it. then you take a radio shack resistor (i forget what value - there're a few writeups around here) and stick it into the harness connector. tape it up & put everything back together. what it does is tell the BCM that it's always bright daylight outside, so it keeps your DRLs on until you manually use your light switch.
Old 12-16-2011, 01:47 PM
1FastBrick's Avatar
Intresting.... I wonder if you Update the BCM to 2000 specs if the lights would work like the 2000's
signguy62
07-29-2015 10:49 PM
Slammed96
07-27-2015 07:22 AM
low2001gmc
07-21-2015 02:09 PM
smit2732
07-19-2015 01:43 PM
oharajo
07-18-2015 09:24 PM
Quick Reply: Difference in 99-02 silverados
