In desperate need of help. Misfire issue.
#22
The motor has 139k on it. The heads have only been off when I swapped in the camshaft and lifters. That was at about 98k miles. The only thing I've done since then, is install the new torque converter and trans cooler.
#23
I've come across this misfire problem before at work. Ended up being a burnt valve. Passed all the compression and leak down tests but when engine is operating it would misfire. Odd I know, but the valve was pitted including the seat in the head. Valve springs were also weak.
#24
I pretty sure I have finally figured it out. To make a long story short, I had someone helping me work on diagnosing the truck who skipped a vital step based on assumptions.
I decided to start over from square one. I pulled all the plugs and started over with a compression test. Every cylinder had 150psi EXCEPT cylinder #1 with 0.
I pulled the valve cover off, and found a broken valve spring on the intake side.
I am going to replace the valve spring today after work. Hopefully this will take care of everything. I'm not sure why cylinders 2 & 4 aren't hitting yet though. Hopefully its sympathy misfires related to cylinder 1. I'll post an update tonight.
Thanks everyone for your help. It has been greatly appreciated.
#26
It should make more psi in that cylinder now.
#29
Well I had some time at lunch to throw in the new spring. I didn't have time to go drive it, but so far so good. All cylinders seem to be firing now. My truck is finally back to normal.
jreynolds7525
08-18-2013 07:41 AM
Snake Eater
04-28-2005 04:29 PM
Scream
25
03-09-2005 10:54 PM
