dbw issues... reduced engine power
Old Jul 26, 2013 | 12:26 PM
mitchellmade's Avatar
MASS seller approved
Default dbw issues... reduced engine power
I am helping out someone with a 03 2500HD changed throttle body, fixed two grounds 103 & 104 , new pps still getting reduced engine power wires ohm checked all came back good any ideas code p1518
Old Jul 26, 2013 | 08:44 PM
Suburbazine's Avatar
  • DTC P1518 sets if the battery voltage is low. If the customer's concern is slow cranking or no crank because battery voltage is low, ignore DTC P1518. Clear any DTCs from memory that may have set from the low battery voltage condition.
  • DTC P1518 sets when there is a short to B+ on the TAC module ground circuit. Inspect the fuses for the circuits that are in the TAC module harness-i.e. cruise, brake. An inspection of the fuses may lead you to the circuit that is shorted to the TAC module ground circuit.
  • DTC P1518 sets if the TAC module ignition feed circuit is shorted to a B+ supply circuit. The TAC module stays powered-up when the ignition switch is turned OFF. When the ignition switch is turned ON, the TAC module is powered-up before the PCM. DTC P1518 sets because no communication is detected by the TAC module from the PCM. Inspect related circuits for being shorted to a B+ supply circuit.
  • Inspect the TAC module power and ground circuits and the TAC module/PCM serial data circuits for intermittent connections.
CIRCUIT DESCRIPTION
The throttle actuator control (TAC) module and the powertrain control module (PCM) communicate via a dedicated serial data circuit. This serial data circuit is separate from any other serial data circuit on the vehicle. Accurate transmitting and receiving of serial data requires not only good circuit integrity but also adequate system voltage. This diagnostic test monitors the accuracy of the serial data transmitted between the TAC module and the PCM. If the PCM detects a loss of data or invalid data, this DTC sets.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
creekrat
Aug 2, 2015 01:27 AM
bsgiffor
Jul 19, 2015 11:14 AM
