Clear headlights
#21
sorry for the ignorance. But what do you mean by DRL (I know what DRL are) to blinkers?
kinda in same boat as OP probably worse. I just want some clean clear plug in play projectors with leds and make the parking lights leds. Is there such a package? 99-02 also
#23
you basically go to your junk yard & grab the brown turn signal sockets (with 6-9 inches of wire) off a truck. grab six add-a-tap wiring connectors (to fit the 18ga wires), and simply tap the new socket wires into the matching colors of your current turn signals. you could alternatively strip a little of the original wires & solder/heat shrink the new ones in for a cleaner, more secure job. (add-a-taps worked for 10+ yrs with no issues on mine).
remove your daytime running lamp bulbs, e-tape over the sockets to resist corrosion, then tuck them out of the way (or simply cut them off if you know you never want to go back). the brown blinker sockets will fit into the DRL housings without trimming - you just have to clock it off to match the bigger tab & then wiggle it in sideways. then it will click into place. voila! now your whole bottom housing is a parking light & flasher. if you're really worried about having lights on during the daytime, then turn your lights on. that simple.
takes you from this:
to this:
Maroon5.3
May 25, 2003 10:36 PM
