Clear headlights
Old Mar 19, 2021 | 06:29 AM
shakenfake's Avatar
Shlumpt
5 Year Member
First off the driver side bottom housing did not snap in properly. Not sure why but it just sits popped out and drives me nuts. Secondly putting the kit together was kind of sucky because there were no instructions and I was just fumbling in the dark basically but I could put that one on me. Third was that the right headlight constantly flickered and went out while driving. Finally figured it out to being the harness so I cut it off and just connected the wires straight together. Also when I start the truck the parking brake has got to be on or else one or both headlights will not turn on.
So yeah pretty retarded in my opinion.
Old Mar 19, 2021 | 06:50 AM
dantheman1540's Avatar
I've had issues with nearly every cheap aftermarket lights not fitting worth a crap. The wire problem is annoying but as you did easily repaired, the parking light issue idk mine are auto on with the light sensor on the dash. I do have an HID igniter that occasionally doesn't light up, for example, this morning I turned the truck on to let it warm up while I walked the trash cans down the driveway, and for some reason, the driver's headlight didn't light up. Got back to the truck turned the lights off for a sec then back on and voila they both came on, that happens probably once every 2 weeks. I think I have a set of igniters but then the headlight mounting pin doohickies suck so bad I'll have to fiddle with it in the dark to try and get them centered properly then likely adjust the beams. Life is just so rough
Old Mar 19, 2021 | 07:05 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Me at this very moment
Old Mar 19, 2021 | 07:22 AM
Be careful that could speed up global warming
Old Mar 19, 2021 | 04:34 PM
_zebra's Avatar
makes children cry
Originally Posted by dantheman1540
words, words, words...
you still ain't converted your DRLs to blinkers yet? slacker!
Old Mar 19, 2021 | 05:33 PM
shakenfake's Avatar
Shlumpt
5 Year Member
You think I can get the ugly out of these and make them look clear or should I just say screw it and get new ones? Buying new lower housings no matter what.
Think they might be a bit too ugly
Old Mar 20, 2021 | 12:28 AM
1FastBrick's Avatar
Custm2500's Rude Friend
If they OEM, Yes you can clean them up.
Old Mar 20, 2021 | 12:29 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Decided to just leave it for now. I’ll have fugly lights until I get new clears.
Old Mar 20, 2021 | 04:37 PM
_zebra's Avatar
makes children cry
with OEM ones, you could totally wet-sand & reclear them pretty easy & have them stay that way for a while.
Old Mar 21, 2021 | 12:08 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Yeah I just went ahead and got some clear ones. No big deal. Amazon chinese special
