cam and stall torque converter ????
Old Oct 29, 2012 | 05:39 PM
slicpartna's Avatar
Default cam and stall torque converter ????
I'm looking to change the cam in my 5.3 suburban
but do i size the cam according to the stall converter or vise versa?
i'm am confused on this
Old Oct 29, 2012 | 05:54 PM
03sierraslt's Avatar
You can do it either way, you just want them to compliment each other. Do you currently have a stock stall and Cam?
Old Oct 29, 2012 | 07:10 PM
slicpartna's Avatar
yes
i have stock converter and cam
Old Oct 30, 2012 | 08:20 PM
slicpartna's Avatar
Default cam suggestions
can someone give me their opinion on this cam?
XR265HR Cam Spec:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,800 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Lobe Separation (degrees): 115
Old Oct 31, 2012 | 06:31 AM
darnie's Avatar
Comp Cams 212/218 LSx Cam "HIGH LIFT"
id say get it.... its a great cam for heavyer trucks. that and a 3000-3200 stall with a big cooler
Old Oct 31, 2012 | 10:08 AM
AndysC3's Avatar
Thats a very good torque cam. As for the converter, depends on what you do with and what you want out of your truck. Do you tow? how much? what is the primary purpose of the truck?
Old Nov 18, 2012 | 04:03 PM
gtyler04's Avatar
Thinking the same thing! Just make em coincide with eachother they need to agree lol
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
Castro45
24
Jul 31, 2015 07:13 PM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
