Quick question about NPT fitting
Old Nov 16, 2012 | 10:25 PM
oakley6575's Avatar
Default Quick question about NPT fitting
I'm getting ready to install my 4" CAI. I'm using ABS tubing that is 1/4" thick. The fitting I bought for my PCV system is a 3/8" barb x 1/4" NPT. I have the hole drilled into the pipe already. Do I have to run a tap through the hole or will I be able to twist it in..?
Home depot doesn't have a 1/4" NPT tap so I would have to order it online. What do you guys think?
Old Nov 16, 2012 | 10:55 PM
2000chevysilverado's Avatar
Make a cut into the first couple of threads in a v shape it will cut its own threads then and put some siliconon it to seal it up
Old Nov 16, 2012 | 11:48 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You don't need to tap it. It'll seal up just fine.
Old Nov 17, 2012 | 10:06 AM
Gadgetized's Avatar
If you wanted to tap it, I am sure a local machine shop would let you use one if you brought the piece in. Any shop should have one, repair shop, machine shop etc. If you didnt want to purchase one, like Roger said it will seal fine. You could even heat the ABS plastic with an industrial hair dryer to soften it a little.
Old Nov 17, 2012 | 12:30 PM
silver-mod-o's Avatar
Hunt&Fisherator
Just screw it in, it's tapered so it'll make it's own threads, just keep some pressure on it until it grabs.
Old Nov 17, 2012 | 05:53 PM
fix-it man's Avatar
exactly what he said, it's better to let it cut it's own threads into plastic because there's a big chance using a tap the hole will be too loose and then not seal.
Just put some pressure on it and turn the fitting in there, then pull it back out, and seal it with your sealant of choice.
Old Nov 18, 2012 | 08:28 PM
oakley6575's Avatar
I tried letting it thread itself but couldn't get enough pressure on it to start. It is hard to hold on to. I'm going to my universities machine shop tomorrow to borrow one. Thanks guys
I ended up going out of town last minute so I wasn't able to work on the CAI anyway
Zizzle
Oct 19, 2017 08:44 PM
Three6GMC
Aug 28, 2015 07:56 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
