cam and stall torque converter ????
can someone give me their opinion on this cam?
XR265HR Cam Spec:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,800 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Lobe Separation (degrees): 115
XR265HR Cam Spec:
Comp Cams 212/218 LSx Cam "HIGH LIFT"
id say get it.... its a great cam for heavyer trucks. that and a 3000-3200 stall with a big cooler
Castro45
24
Jul 31, 2015 07:13 PM
KyleW707
Jul 29, 2015 08:17 AM
