A/C problems, need suggestions...
So my A/C went out and I am trying to diagnose what is broken.
Currently, the compressor won't kick on when I press the A/C button or the Recycle Air button, but the fan speed works fine, it's just ambient air that comes out. I jumped the low pressure sensor with a wire, and it still didn't come on. The belt on the compressor is spinning, but the clutch just won't engage. Checked the A/C fuse already, are there others I should check?
I already have another compressor I picked up from a member on here for cheap, but I would rather not replace it if that's not the problem.
Thoughts of ways I can diagnose this myself?
Noticed one day that the a/c wasn't blowing cold, popped the hood and saw that the compressor clutch was engaging and disengaging for a few seconds at a time with the a/c button depressed. Then after a few days, the compressor wouldn't engage at all.
I probably should have included that description to begin with, but forgot about it until you mentioned something.
What about having auto climate and having the a/c work-clutch engage when using that, but when you hit the a/c button it no longer engages and works. Anybody got any ideas on that...? The a/c is controlled by two different trigger possibilities right..?
