A/C help...
Old Jul 19, 2009 | 09:30 PM
ap2002's Avatar
Default A/C help...
my 2004 has a digital dual climate control for the a/c, every once in a while only passenger side will blow some cold a/c and the driver side will blow hot air or vise-versa,... its done this about 4x now in the past month....
what can be causing this? maybe i need to change the digital dual climate control unit?
thanks..
Old Jul 19, 2009 | 09:40 PM
charcold-bowtie's Avatar
im not sure but mine usually does it after disconnecting the battery? it has to do with some little door i think....
Old Jul 19, 2009 | 09:43 PM
budhayes3's Avatar
PT's Slowest Truck
The blend door actuators are known to fail and will cause the symptoms you describe. If you search this section for "actuator" you'll probably find a bunch of info about them, and possibly a pn. I believe that Torque_Wrench has posted some actuator info...
Old Jul 20, 2009 | 08:26 PM
ap2002's Avatar
hmm... 50% of the time it happens its becuase the battery has been disconnected?
Old Jul 20, 2009 | 08:29 PM
dlt76028's Avatar
I know both silverados i've had will mess up kinda like that. if im driving and turn it to heat a little then if i turn it back to cold it will not go back to cold. i found that turning it off and back on it resets or something and goes to cold( i even do this while on the highway, just let it coast for about 10 seconds)
Old Jul 21, 2009 | 05:56 AM
Tootall's Avatar
mine does that ever so often. . . . I know that it has something to do with the blending doors, but that's it.
Turning off the truck, and restarting it takes care of it for now.
FormulaZR
Sep 14, 2015 05:23 PM
Hpinnovate
Sep 4, 2015 02:28 AM
creekrat
Aug 2, 2015 01:27 AM
