Burning Oil?
Old Aug 8, 2005 | 11:42 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Burning Oil?
I got the "Check engine oil level" light a few minutes ago and sure enough my oil was at the very bottom of the dipstick. I have no visible oil leaks and the driveway is clean. Why would I be using oil all of a sudden? I'm due for an oil change in 2 weeks and it has been about 3 months and 3500 miles since the last. My truck had 66K miles on it so I figured it should not be burning oil already, should it? Does the computer notice if it is only a qt. low or does the bottom of the stick mean I am missing a few quarts? If it's not leaking, it must be burning up somewhere. Any ideas? Mods in sig but don't think that is an issue. I have not modded anything in months and this the first time I've seen this light. Maybe the service station didn't quite get enough in there during the last change?
Old Aug 8, 2005 | 12:09 PM
white1's Avatar
I had this same exact thing happen to me just recently. With no visible level on th edipstick, it took 1 qt to get back to normal operating level. I had just changed my PCV valve last oil change, and think thats my problem. If it doesn't go away, it may be time for a 6.0 . I don't feel like chasing the problem down
Old Aug 8, 2005 | 12:59 PM
JERRY2500's Avatar
14 Second Truck Club
Check your PCV. I don't know how the Radix is set up but on the STS there's a preasure switch in the PCV line that close when it see 1# boost so you don't pressurize the base and vent the pcv to the atmosphere.
Old Aug 8, 2005 | 07:28 PM
Onyx 02's Avatar
I had the same thing happen to my '02, about 2 years ago. Weird - I had about 60k something miles too. Although, I missed an oil change it only took a quart to fill 'er up again. I have noticed that my oil pressure has been reading higher ever since. It used to read at 60 psi, now it sits at around 65 psi. It's been 2 years and I haven't had any problems, but that I think that "tapping lifter" is nosier.
Old Aug 9, 2005 | 09:41 AM
1SlowHoe's Avatar
Put in a qt and everything seems fine. I guess I will cjeck out the PCV when I get time. When I started the truck to go get the oil, the light didn't come back on but I only went 1/2 mile so maybe it didn't have time to read it. Weird.
Old Aug 9, 2005 | 10:38 AM
BLACKHD01's Avatar
My truck uses about a quart every 1,000 miles, so you are lucky in that regard. They say that these LS1's are notorious for using oil, I have changed the pcv to the fixed oriface style, and it didn't help much. I have a oil consumption test going on right now with the dealership to see if I can get the problem fixed. I also have no visable oil leaks and my truck does not smoke. My truck started this at about 45,000 miles, I now have 55,000 on it.
lukn4trbl355
Oct 21, 2015 11:19 PM
Staggered 02
Oct 9, 2015 05:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
