bunch of motor racket
Old Apr 19, 2007 | 02:04 PM
sdimess84's Avatar
Default bunch of motor racket
Just installed a 350 in my truck (59 GMC). vortec style heads and intake. edelbrock carb. Start up the truck runs, idles, and revs fine. Put it in drive and give it hard throttle or put it under a load, it sounds like a bunch of raddleing or a deisal truck going down the road. Any idea what it might be?
Old Apr 19, 2007 | 05:55 PM
Sounds like detination. Try adding a little fuel and pulling a little timing. Your timing at idle may be good, but your advance may be too agressive. What compression are you running?
Old Apr 20, 2007 | 08:16 AM
sdimess84's Avatar
I think im running 9:1 or 10:1.
Old Apr 20, 2007 | 08:17 AM
sdimess84's Avatar
Thanks for all your help
Old Apr 20, 2007 | 12:44 PM
FastCrewCab4x4's Avatar
I Had a 327 in a s10. it rattled some, It was the friggin harmonic balancer coming loose. Lunati made the crank snout a little too small..
Old Apr 21, 2007 | 07:32 AM
sdimess84's Avatar
well i had this motor in a s10 before and ran perfectly. I put new intake and carb on it and it does this. My dad think it could be coming from the transmission/transfercase. Im not sure Im so lost on it.
Old Apr 21, 2007 | 09:55 AM
A new carb and intake means you pulled the distributer out and the new carbs air fuel may not be set right yet.
Old Apr 21, 2007 | 01:22 PM
litreddevil's Avatar
Banned
distributer MAY BE OFF A TOOTH ALSO
Old Apr 21, 2007 | 06:57 PM
sdimess84's Avatar
I set the timing today, it was way way advanced. i set it down to about 4 degrees adcvanced. Couldnt test though, now the rear end is making some noises so now i have to investigate it. LOL if its not one thing its another
TrendSetter
Nov 26, 2018 07:18 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
FlyingLow
Nov 24, 2015 10:05 AM
03chevytruck
Sep 14, 2015 09:15 PM
