Budget build. Like really low
Old Mar 15, 2015 | 07:50 PM
  #61
Leegreens's Avatar
Pulled out the A/C & front sway bar today. Finally warm out & dry enough to lay on the ground.
Gutted passenger door panel, headliner/visers. Alot of weatherstripping.
Noticing all the extra wiring. I might have to get a harness made so i can just do switches & push button start. Place here in mi makes them cheap
Old Mar 16, 2015 | 06:59 AM
  #62
Leegreens's Avatar
Can i run my rack & pinion dry & toss the pump? Reason is its leaking & i dont want to spend money on the stocker i'd rather save for manual at 1 point but i need to pass tech inspection & cant leaking.
Old Mar 18, 2015 | 07:40 PM
  #63
Leegreens's Avatar
Well i gutted it. Even threw out the carpet & jute. This wirings a mess.
I got most of dash & air bag i'm happy the actual top dont really have to come out.
Will the truck run if i pull the drivers air bag?
Looking at racing seat kits , started working for a friend again & got a co-worker whos a fabber. Said do a cage for free so thats a score. Just have to get there.
Old Mar 22, 2015 | 01:24 PM
  #64
Leegreens's Avatar
Hung my battery box up. I kept my hitch & spare winch cuz seen ppls traction probs. but this box is in wY of spare. Maybe i can hide it some how w a fake cut out spare. I also have a false battery for the front.
I used what i found in my barn & some bought hardware in stainless. Name:  836C2295-3A88-432F-A0ED-4EC0BD4D6312-63501-000012CADBCCAD9F_zps2cda8f2f.jpg
Will i have any probs mounting it here?
Old Mar 29, 2015 | 02:23 PM
  #65
Leegreens's Avatar
What gauge wire should i use for my batt. Relocation?
If i have a slight slip on my 4l60 when its shifting between gears. Can i save it w servo & shift kit or should be looking to rebuild?
If so i'm going Th400 for the fun of shifting myself.
Old Mar 29, 2015 | 03:32 PM
  #66
gamble686's Avatar
Most likely if it is slipping it is too late.
Old Mar 29, 2015 | 05:25 PM
  #67
Leegreens's Avatar
Ok i'll ride it out like this. Only does it when i ***** foot it.
http://youtu.be/UHoCZYGAvYI
Old Mar 29, 2015 | 07:35 PM
  #68
Leegreens's Avatar
My photobucket wont do the video. Its under: budget silverado burnout- on youtube.
Some baseline stuff. I really want to get the weight & a 1/4 run.
Old Apr 18, 2015 | 09:52 PM
  #69
Leegreens's Avatar
4200lbs today at the scale. had 285's w the steel wheels & still full stock exhaust. But no front bumper.
Think the stock aluminum wheels, coil-overs & the headers will lose another 200lbs?
Old Apr 18, 2015 | 10:38 PM
  #70
FFDP's Avatar
Maybe 100lbs ish.
Headers will likely add weigh, more metal. Stock 16in AL rims are like 18-20lbs each I think?? Should lose several pounds per wheel taking the steels off. If the 285's are LT's being KO's, you might lose an extra few pounds switching back to a smaller tire.
