Brake Pads
Haven't heard much about the Hawk ceramics...since they are ceramic they should last a long time and have very little dust, but there's usually some sacrifice in stopping performance. I know that I've read of a lot of guys complaining about the Hawk HPS pads making noise and dusting like hell, but most have reported good stopping performance from them.
Here's my thread with my EBC Green Stuff review:
https://www.performancetrucks.net/fo...d.php?t=480687
I just installed EBC Green 7000's in front and 6000's in rear and am totally impressed with them. I previously had Praise Dyno cryogenically treated performance pads and was very happy with them, but the EBC Greens are even better.
I've got another question. My brakes are pulsing bad, I currently have power stop rotors (I think, they could be ssbc) but I remember when I got them that they seem to be just cheap rotors with slots cut in them. They started pulsing about 20-30K in and have just gotten worse. The brake flush helped some, but I want to get rid of the fronts for sure, should I replace the rears also, or just turn them? if I do everything it will run me $680 for everything, a little steep.
Personally, if you thought that the PowerSlots looked cheap, I'd do new rotors all around and start fresh. I had thought that the PowerSlots were of good quality, but then I saw tdrumm's rotors when we did front brakes on his old GP, and they were rusted all to hell IIRC. I believe that his brakes were pulsating also.
Honestly, you can get some cheap white box factory replacement rotors and the brakes will act and feel the same as if you dropped the dough on expensive slotted rotors. I've had good luck with the rotors that NAPA offers. Actually, slotted/drilled/dimpled rotors don't do much in a daily driven or 1/4 mile application, as the slots/holes/dimples don't do much but remove surface area from the rotor for the pads to grab on to.
I must say though, I'm extremely happy with my PraiseDyno cryogenically treated slotted rotors that are on my truck...they have resisted oxidation great, and are totally true with no pulsations. I went through two sets of factory rotors that rusted to **** very quickly here in the northeast.
This is just the thread I needed to come across... my rotors are so warped the whole truck shakes violently under light braking, something I've been needing to do, but haven't had the time to do the research.
I think I'll just start anew, I remember being in Austin (allot more hilly then Houston) a few times and coming to a stop after driving in the hills, the truck would shake Violently, almost like the road was a bunch of small speed bumps. Plus the EBC's rotors have a nice finish.
I am looking at the yellow pads also, but they say they are higher dust then the Greens, but how much higher? The greens don't produce much at all.
