Brake lines
Old Aug 1, 2015 | 10:32 PM
mhorn0817's Avatar
Default Brake lines
Wanting to replace brake lines on my truck but can't find a kit for my specific truck. I have a 02 gmc Sierra 2500hd ext cab short bed 4wd. Found it for long beds, crew cabs, rwd but not my exact setup but found it for 2500. Are 2500 and 2500hd Brake lines the same?
Old Aug 4, 2015 | 09:34 AM
Mr. Chainsaw's Avatar
are you looking at the dorman kits? I just put one on a customer's truck, and with all the hassel that was involved, it's easier to just make them and bend them from scratch
Old Aug 6, 2015 | 10:34 AM
SLOPONY's Avatar
i bought a kit from the chevy dealer. with my discount it was $76 out the door. Kit contained 5 prebent steel lines, that were also plastic coated. It took me 2.5 hours to remove all the old lines, and install all the new ones using jack stands, and no lift. I also replaced all 4 rotors, all pads, calipers, brackets, and installed braided stainless steel brake hoses. The whole job took me 5 hours to complete, and was well worth it.
The chevy dealer has kits listed by vin, and mine was an exact fit, with no issues what so ever. regular price before a commercial discount is around $100
Old Aug 12, 2015 | 02:07 PM
76k10chase's Avatar
I just recently did mine for an 03 extended cab long bed, they are usually sorted by wheelbase, but I know that Rockauto has all of the different options listed as possible replacements. GM Parts Direct also allows you to put your model info and I think even vin which can get you a part number for the GM replacement coated lines. Also make sure that the lines are for the 9,900 lb brakes which is what the 2500hd has (rpo code JH6 I believe) and might be different from just a 2500, as well as the HVY rpo code for a 2in body lift. Personally I went with the coated AC Delco lines from GM and while they were good quality, there were multiple bends that had to be straightened out (due to the box they are packaged in) but there are stickers that tell you where to straighten, other than that the hardest part was doing the front right line because it is all one piece. I did only pay about 40-50 from Amazon for these lines, so even though it took a little extra time it was worth it. This might be your set here, but double check it
Amazon.com: ACDelco 22933188 GM Original Equipment Hydraulic Brake Pipe Kit: Automotive Amazon.com: ACDelco 22933188 GM Original Equipment Hydraulic Brake Pipe Kit: Automotive
Old Mar 3, 2016 | 10:20 AM
Jlipton72's Avatar
Classic Tube sells a full Stainless kit pre-bent with braided lines, expensive but it is a nice kit. Used it in my duramax back when I had it
Old Mar 5, 2016 | 12:19 PM
2002_Z28_Six_Speed's Avatar
I've had terrible trouble buying non-oem items from RockAuto like oil cooler lines, tranny lines and hoses. I got a non GM dip stick from RockAuto once and the mounting tab separated from the tube before I could even bolt it down on the block.
Old Mar 6, 2016 | 07:36 PM
Beatdown Z's Avatar
Laid Back
I've installed two sets of Dorman Stainless brake line kits from Rockauto. They're nice, I'd recommend them.
Old Mar 6, 2016 | 08:00 PM
Dorman is usually OK. Better than most.
simman22
Jan 21, 2017 10:27 PM
carid
Oct 28, 2015 08:24 AM
Noah Burns
Sep 13, 2015 09:28 AM
Pimpinpete
Sep 8, 2015 07:39 PM
Alco
Sep 4, 2015 04:08 PM
