Bolt size
I need to know what is the bolt size that goes into the back of the block, where the transmission bolts to the block? Anyone know the size of the thread that is needed?
Thanks in advanced.
Thanks in advanced.
Can't remember the length and diameter but its standard thread.
Just go to the dealer and get some new ones. Personally I like the factory bolts better because they'll stay in your socket easier.
yes. Your transmission bellhousing bolts have threaded studs on them. Usually your Trans dipstick tube is bolted onto the bellhousing. These studs allow you to just undo a nut instead of the entire bolt. and as i mentioned earlier. that stud helps the bolts stay put in a deep socket when trying to put them back in.
