Billet Bow Tie Install?
Old Jul 28, 2005 | 07:42 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Billet Bow Tie Install?
How does it install on the grill. On my s-10 there were two nuts you took off and it just popped off. I took my grille off last night to clean the billet grille in it and take it off to put in my new grille that should be here to day. I ordered a billet bow tie for it and it doesnt look like there is any bolts or anything. So those that have the billet bow tie how does it go on?
Old Jul 28, 2005 | 09:03 AM
three83's Avatar
On my 05 Chevy the factory one was bolted on and all I had to do was unbolt it and bolt on the billet bow tie. Got the billet bow tie from Billet Specialties. My 00 Chevy was a different story. I ordered it from some website and when I got it it only had some threaded holes on the back of the bow tie and the factory bowtie clipped in. I had to go to bolt and nut store and got some all thread that fit the threaded holes on the back of the bowtie. Then I had to drill out part of the grill to get the all thread through the grill. Then I used a washer and nut to hold it on.
Old Jul 28, 2005 | 09:07 AM
1slow01Z71's Avatar
So do you pop the bot tie out from the front? Just put a crew driver under the edge and pop it out or what?
Old Jul 28, 2005 | 09:15 AM
three83's Avatar
If I remember right i took off the grill and used a screw driver to remove the bow tie from the back. Should be some gray clips on the bow tie where it clips on to the grill. I still have my stock bow tie from the 00 Chevy and could take a picture of it if you think that would help?
Old Jul 28, 2005 | 10:01 AM
1slow01Z71's Avatar
If its as easy as you say it is then it shouldnt be any big deal. I take a closer look when I get home tonight.
Old Jul 28, 2005 | 10:16 AM
TXsilverado's Avatar
pull your grille off and its self explanitory...
Old Jul 28, 2005 | 05:58 PM
02BlueStepside's Avatar
The stock should clip off. The replacement I put on had two threaded studs in the bowtie and nuts and washers to put on the hold it to the shell. No drilling for mine.
Old Jul 29, 2005 | 11:24 AM
Nigel215's Avatar
yea, the factory one should just pop out from behind from these 2 plastic clips, be careful not to squeeze too hard, i broke one of mine. then the billet one bolted right in their.
Old Jul 29, 2005 | 11:32 AM
1slow01Z71's Avatar
Thanks guys got it on yesterday
Dan Neumann
11
Aug 7, 2022 09:06 AM
justuc
Jul 24, 2015 11:52 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
