Belt Squeak
Old Nov 23, 2009 | 08:09 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default Belt Squeak
alright changed out my belt cause i thought at 63,xxx miles i was getting squeak from the belt just being used....so after the change i still get some squeak especially when it's damp out...if it's not the belt anyone have any ideas? tensioner maybe?
Old Nov 23, 2009 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
If you have the correct size belt on there, I'll bet that your squeak is coming from one of the tensioners, I've had to replace both of mine. My upper one used to squeak when it was cold, and my lower one sounded like a jack hammer when I used my a/c.
Old Nov 23, 2009 | 12:45 PM
LowBlack99's Avatar
Also might check the water pump to see if its dripping coolant on the belt.
Old Nov 23, 2009 | 01:37 PM
2000chevysilverado's Avatar
I bet its just one of the tensioners happens alote bearings loose oil so they start to squeak just spray some wd40 in one of them it will work for awhile but you will find out which one it is and not have to buy both of them
Old Nov 23, 2009 | 01:58 PM
OneQwikSS's Avatar
no coolant...should be the right size belt pretty sure i've got the 105 amp alt not the 150...
Old Nov 23, 2009 | 02:03 PM
JAVI05's Avatar
i would spray a lil armor all on the belt..let it sit. i always get rid of mine that way,, but if the noise comes back then yea i would bet its a tensioner..
Old Nov 23, 2009 | 02:10 PM
OneQwikSS's Avatar
i mean idk about armor-all wouldn't that cause dry-rot? like if you use armor-all on a dash & then never use it on the dash again it'll dry-rot the dash pretty good....
hopefully it's just the actual tensioner pully and not any of the other ones...cause if i have to change a water pump on another one of these LS motors i'll flip...but at least then it would be a reason to put e-fans in...
Old Nov 23, 2009 | 02:18 PM
JAVI05's Avatar
never had that problem.. lol.. worth a try to get rid of the noise tho.. i still have my original belt.. 75,000 miles. it tried to sqweak one day sprayed it and it hasnt come back at all... worth a try. imo. its better than replacing some tensioners and the noise still be there..lol.
Old Nov 23, 2009 | 02:20 PM
DV2000NJ's Avatar
13 Second Truck Club
Don't spray anything on the belt, ever.
Did you change the A/C belt?
Old Nov 23, 2009 | 02:24 PM
JAVI05's Avatar
why not?
