Belt Squeak
formerly 2004RST (changed 11/19/2012)
alright changed out my belt cause i thought at 63,xxx miles i was getting squeak from the belt just being used....so after the change i still get some squeak especially when it's damp out...if it's not the belt anyone have any ideas? tensioner maybe?
If you have the correct size belt on there, I'll bet that your squeak is coming from one of the tensioners, I've had to replace both of mine. My upper one used to squeak when it was cold, and my lower one sounded like a jack hammer when I used my a/c.
I bet its just one of the tensioners happens alote bearings loose oil so they start to squeak just spray some wd40 in one of them it will work for awhile but you will find out which one it is and not have to buy both of them
i mean idk about armor-all wouldn't that cause dry-rot? like if you use armor-all on a dash & then never use it on the dash again it'll dry-rot the dash pretty good....
hopefully it's just the actual tensioner pully and not any of the other ones...cause if i have to change a water pump on another one of these LS motors i'll flip...but at least then it would be a reason to put e-fans in...
