AWD to 2wd conversion 04 escalade
Old 06-17-2014, 08:26 PM
In-Zane Moderator
ZONES89RS's Avatar
Default AWD to 2wd conversion 04 escalade
What would I need?
Some say a transfer case from a 4x4
Some said a rwd Trans and DS
And one said removing the transfer case and using a rwd tail shaft would work.
Old 06-17-2014, 09:04 PM
brewster240's Avatar
Rwd trans, or completely disassemble trans to change out put.
Rwd drive shaft.
2wd front hub bearings.
Maybe trans xmember?
Old 06-17-2014, 09:15 PM
In-Zane Moderator
ZONES89RS's Avatar
Was told that the front hub bearings can fall apart without the shafts in, I swore that they looked like the 2wd pieces. But at thisnpoint I'm not gonna find out the hard way, if I go 2wd.
Old 06-17-2014, 10:15 PM
sammygroundzero's Avatar
I cut the shafts at the end and bolt them to the hubs but when i park at an incline truck wouldnt stay it would move by itself
Old 06-17-2014, 10:28 PM
mdwatts11's Avatar
Why don't you just swap to a 4wd case and only run in 2wd? Or you trying to save weight?
Old 06-18-2014, 03:20 AM
In-Zane Moderator
ZONES89RS's Avatar
That's what I wanted to do, but wasn't sure that the Trans would be the same and all, any idea?
Old 06-18-2014, 03:21 AM
In-Zane Moderator
ZONES89RS's Avatar
This is al because of some loud sharp sound by the way.
Old 06-19-2014, 08:32 PM
In-Zane Moderator
ZONES89RS's Avatar
After investigation, the rear end is bent down like it was dropped off a lift or driven off a edge. I noticed the whole bottom is scarred.
The axle is leaking where it is pressed into the diff housing, the rear tires are wearing as if it was the front with a bad alignment. So, the rear right axle is able to move outward and rub the rotor on the caliper bracket. That's my noise.
Old 06-19-2014, 09:16 PM
Quyonmob's Avatar
Retitle thread AWD to FWD now.
Old 06-20-2014, 03:49 AM
In-Zane Moderator
ZONES89RS's Avatar
Rear axle swap would be right but I know how to do that, so wouldn't be a point lol.
Quick Reply: AWD to 2wd conversion 04 escalade
