AWD to 2wd conversion 04 escalade
In-Zane Moderator
What would I need?
Some say a transfer case from a 4x4
Some said a rwd Trans and DS
And one said removing the transfer case and using a rwd tail shaft would work.
In-Zane Moderator
Was told that the front hub bearings can fall apart without the shafts in, I swore that they looked like the 2wd pieces. But at thisnpoint I'm not gonna find out the hard way, if I go 2wd.
In-Zane Moderator
After investigation, the rear end is bent down like it was dropped off a lift or driven off a edge. I noticed the whole bottom is scarred.
The axle is leaking where it is pressed into the diff housing, the rear tires are wearing as if it was the front with a bad alignment. So, the rear right axle is able to move outward and rub the rotor on the caliper bracket. That's my noise.
