Advice needed for 6.0
Old Sep 2, 2021 | 06:23 PM
  #41
arthursc2's Avatar
So look under your hood. The crossmember is the front of the lower control arms. The crank pulley is like 2" from the front of the cross member. The majority of the engine weight is behind the center of the front axle
if you really wanted you could make mounts that drop the engine 2" and move it back 2". Any more and I fear you'll have firewall issues
but being manual, that means your shifter changes too
I want to be clear; I don't think you shouldn't do the aluminum block, I think you should do what makes you happy: that's the biggest tangible difference between the 2. Imo
Old Sep 2, 2021 | 10:35 PM
  #42
adriver's Avatar
Its a long shot on the 3.08s, but I know if I was to change that would be it. It would be a while if ever.
I have my seat as far back as it can go. I wouldn't mind if the shifter came back about another inch or two. Honestly though, unless I could already buy those mounts, I know I won't be making em.
I think when it comes down to it there are benefits to either one. Its going to be a budget build with either one, so that might effect the outcome. If I could at least get something better, and then work on something serious. I really don't know at this point.
I do appreciate everyone contributing to this conversation.
Old Sep 3, 2021 | 11:05 AM
  #43
_zebra's Avatar
makes children cry
it's a bit of a stretch, but with the gearing of the 4500, that gets you as close to a daily-drivable 1st gear (5.61) as you're gonna get & would carry the rest of your gears longer to where you ultimately highway cruise @ 1700rpm. you won't have great acceleration, obviously, and would definitely have to downshift.
the tough fact here is that neither new venture transmission is good for "sporty" driving or feel.
Old Sep 3, 2021 | 11:46 AM
  #44
arthursc2's Avatar
Did you already mention this, are 4.3 S10 NV3500s a better gearset?
Old Sep 3, 2021 | 02:13 PM
  #45
_zebra's Avatar
makes children cry
yes & yes
but no
Originally Posted by _zebra
ps - you've likely seen that the nv3500 used different (better) gear ratios in the dodge trucks & S10s, RPO M50... but before going down that rabbit hole, the transmissions ain't interchangeable because the dodge has a different bolt pattern & input shaft while the S10 has a different tail shaft.
m a y b e... there's a potential to rebuild a MG5 transmission with M50 gears inside, but i ain't looked into that. i simply did a nv4500 swap & drove it like a 4spd.
Chantro
11
Nov 26, 2017 03:17 AM
Hillbilly Silverado
Mar 16, 2017 10:53 PM
Curdoghunter
13
Jan 25, 2010 11:52 PM
optikalilution
Jul 9, 2008 03:23 AM
nightrunner
Feb 6, 2007 07:14 PM
