AC doesn't blow cold anymore.
I did a search and came up with a lot of stuff about AC and E-fans. But, I was driving from Fresno to Chico at freeway speeds and I had the AC on full blast and it was cool not cold. It used to be too cold to turn blast now its only cool.
I have 50K mills on it now. Do I need to recharge already?
Hey.. at least yours is cool.. I have a rather large hole in my a/c condenser
You might wanna buy one of those little recharge thingys with the gauge.. its like 25 bucks or so. It shouldnt be time to recharge it already tho.
Do these AC units have a "sight bubble" so you can check your freon level like the older ones?
im not quite sure what you mean.. but u can check the level with the gauge connected with the ac full blast.. when the ac clutch is ingaged the level will be shown on the gauge.. i think 40 psi is where you should be.. not sure tho.
I would check everything else before add freon.I had a bad pressure switch on mine.Check your coil up front it my be dirty.Be carefull not to bend the coil fins.Are you running efan?Check to make sure they are coming on when the compressor is engaged.
Good luck
Good luck
I also need help on this mine blows cold at highway speeds but upon coming to a stop it will turn hot then back to cold. How do you check the dryer? Also my fan runs by switch so no problem there. You really need gauges to check high and low sides. Anyone know if the pcm controls the ac as in maybe something in the tune turning it on at a certain rpm or something?
Skip Fix
22
Jul 9, 2016 07:08 PM
TrickTurbo
Sep 23, 2015 08:41 PM
Orlerr
Sep 21, 2015 08:32 PM
