99 sierra speedo way off??
Easier method would be to block the front tires, jack up the rear end, put the trans in neutral, and turn the driveshaft by hand and count the number of driveshaft turns required to turn the wheels one turn. That number is your gear ratio. And you wont have to buy new fluid and gasket. Unless you want to change the rear oil.
Custm2500's Rude Friend
If the gear ratio is off it will usually throw a Check engine light and an ABS light. The front wheel speed and the trans ratio combined with rear gear ratio and rear tire size need to match within a specified range.
Most likely the tune has the wrong tire size and needs to be adjusted. Even with the correct tire size, it still may need a fine adjustment. With the correct tire size, Mine said I was doing about 85 when a GPS only showed 81. There is an option in the tuning software that will allow you to fine tune and correct for this.
carid
10-28-2015 08:24 AM
