5.3 into '92 rcss almost done
Old Dec 11, 2006 | 11:25 PM
Default 5.3 into '92 rcss almost done
Guys, here is a progress pic of the swap I'm doing on my old truck. '05 5.3 and 4L65 into a '92 Sierra rcss. Mods are 228/232 .588 .595 110lsa, Patriot double gold springs, hardened push rods, Shaner ported TB, P.I. Vigalante 3200, and Detroit True Trac. Truck is being tuned by us using HP Tuners. Its just about done. All the factory gauges work. A/c is coming as soon as I have time to make a custom a/c bracket.
Old Dec 12, 2006 | 05:46 AM
KevinF56's Avatar
awesome man. that will be a fun truck.
Old Dec 12, 2006 | 07:01 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
MORE PICS!!!!
Old Dec 12, 2006 | 07:14 AM
Gran Patron's Avatar
Badass,man!! Every time I see an LSxx engine in the OBS I get pressured just to go head and do my swap already.
Old Dec 12, 2006 | 08:07 AM
ridnlow's Avatar
almost finished up with my swap as well.. looks good, did you fab up the air intake??
Old Dec 12, 2006 | 09:00 AM
since we are an STS dealer, I had one of the elbows used in the kits. I was thinking there would be a little better air than up higher.
Its just a coupler to the TB, MAF, elbow, 3" pipe going down, and filter.
Old Dec 12, 2006 | 09:22 AM
ridnlow's Avatar
not a bad idea, im trying to figure out what im going to do as far as that is concerned.. also did you have to buy an adapter to get the tach wire to work?? Ive got mine hooked up but the factory guage doesnt work..
Old Dec 12, 2006 | 10:05 AM
you will need a tach signal divider from bakerelectronix to make it work right.
I will look and see which pin number it is from the pcm. If the colors on the old harness are the same as mine, there is a white wire going into the firewall. That should be connected to the new pcm. ON the inside of the firewall, there is a box (I havent done this yet) that you splice into the white wire with the tach signal divider to make it read right.
Old Dec 12, 2006 | 11:37 AM
ridnlow's Avatar
thanks for the help, i guess i will get around to that once we get the tranny in and everything.. hptuners will have to do for now..
Old Dec 12, 2006 | 06:18 PM
NBred94's Avatar
Originally Posted by 1BADC10
MORE PICS!!!!
+1
