4L80 swap, didnt trim the long yoke. Whats the potential harm?
Old Feb 28, 2019 | 10:17 AM
HOT_SAUCE's Avatar
Default 4L80 swap, didnt trim the long yoke. Whats the potential harm?
So I did the swap and didnt trim the long yoke. everything is working as it should but there is a noise in first gear only. As soon as it shifts to second gear the noise goes away. Best way I can describe the noise is a "whirring" sound. Could the sound im hearing be from me not trimming the yoke? What are the potential problems i could run into from not trimming it?
Truck is an 03 RCSB 4.8 and trans is out of a 06 express van with 60k miles. Circle D converter, HD2 kit. HD2 kit done by reputable transmission shop.
Seems to me like the noise would always be present if it was an issue caused by the yoke being too long.
Thanks in advance.
p.s. I know, I know, i should have just trimmed it like everyone says, but it fit with what seemed like plenty of room so i just sent it.
Old Feb 28, 2019 | 10:55 AM
zz454Chevelle67's Avatar
My 4L80 makes a whining noise in first gear and has since I installed it 6 years ago. Its not very loud but it is there. When you say trim the yolk do you mean the drive shaft? No way my original driveshaft would fit, I had one made.
Old Feb 28, 2019 | 11:12 AM
HOT_SAUCE's Avatar
No Im talking about the yoke. I got a th400/4L80 long yoke and the conversion ujoint (1350 i think?) everything fit right in. Ive heard of people having their drive shafts cut down or having one made but mine worked fine.
Old Feb 28, 2019 | 12:12 PM
Merctech2's Avatar
I trimmed mine but it does make noise in first, always have since the install. Best I can describe is a whine, maybe a whirl.
Old Feb 28, 2019 | 05:56 PM
MikeGyver's Avatar
You both sound like you are describing what I read is a noise made by the blades in the torque converter cavitating. I wish I could find the article again, but one thing that I remember is that the noise can be eliminated during manufacture or rebuilding of a torque converter by cutting some notches in the trailing edges of the offending blades. I don't remember which blades, either. Not that which ones matter, I just wanted to bring up cavitation as a possible source of the noise. My truck did it when I put in my first aftermarket converter. A kind of far away whirring, whining, whistling underwater, turbine like, turbo under water like noise.
Old Mar 1, 2019 | 07:30 AM
HOT_SAUCE's Avatar
After digging around on google and calling a few shops, there is a common explanation. 3 of the 5 people i talked to said the sound im hearing is straight cut gears. They all said the straight cut gears are one of the things that make the 80e strong and the noise is completely normal. The other 2 said they didnt know what it could be without tearing it down. I feel a little better about it now though haha
Old Mar 1, 2019 | 04:41 PM
Merctech2's Avatar
That’s good cause I’ve been beating the **** out of mine lol
sleeperlqx
Mar 3, 2017 02:48 PM
ACLR8R
Dec 26, 2013 09:14 PM
dirtydeeds
Oct 28, 2012 12:45 AM
SlvrSierra4.8
21
Jan 27, 2007 07:33 PM
Yelo
Feb 2, 2006 09:01 AM
