4l80 swap Yoke and u joint
Old Dec 23, 2013 | 07:27 PM
ACLR8R's Avatar
Default 4l80 swap Yoke and u joint
Was wondering if anyone knew which yoke and u joint to get for the swap on an 05 rcsb. After searching I believe I need the th400 long yoke and remove 5/8in, but not sure on which ujoint set up.
Will this work?
GM Turbo 400 Transmission Slip Yoke 4L80E TH 400 1350 U Joint | eBay
Not sure if that uses the correct u joint.
Thanks!
Old Dec 23, 2013 | 07:53 PM
brandon6.0's Avatar
Precision 447 u joint from napa should do the trick. I run it just fine.
Old Dec 23, 2013 | 09:02 PM
Jetn3's Avatar
80e swap guys, how's these eBay slip yokes working for you guys? Any worries of breakage?
Old Dec 23, 2013 | 09:07 PM
GMCtrk's Avatar
There are FIVE different types of 4L80 output shafts. You need to determine what type of output shaft you have before buying a slip yoke.
Old Dec 23, 2013 | 09:14 PM
brandon6.0's Avatar
Mine is an ebay yoke that i cut down about an inch
Old Dec 24, 2013 | 07:43 AM
ACLR8R's Avatar
That works with which yoke? and the stock shaft?
Oh, did not know that. I pick up my tranny from the builder on Monday. Its a 2000+ core so it has the top bolt (not that it really matter).
Do I just figure out what year it is to determine the slip yoke?
Just trying to get everything lined up so the swap is as quick as possible.
Thanks!
Old Dec 24, 2013 | 07:09 PM
brandon6.0's Avatar
Yeah its a basterd u joint. Fits a 4l80e yoke ands stock shaft. U should be fine with a ebay yoke. Alot of us get the longer one and cut it down to what length u need.
Old Dec 24, 2013 | 07:14 PM
Ferocity02's Avatar
Is it a 3R joint?
Old Dec 26, 2013 | 04:31 PM
brandon6.0's Avatar
I think it is. Its greasable and looks heavy duty. Runs about the same price as a 3r from dennys driveshaft.
brandon6.0's Avatar
Havnt broke one yet knock on wood.
