427 sbc stroker truck motor build
Old Aug 22, 2018 | 12:31 AM
EmeraldFlame772's Avatar
Default 427 sbc stroker truck motor build
How does this sound this will be going in a 95 Chevy k1500 with Holley sniper efi
blueprint block pro filer 210cc heads 2.05 intake valves 1.6 exhaust 9:8:1 compression 1.5 Harland Sharp roller rockers crane recommended the 216/224 cam with a 112 lsa .509 intake and .521 exhaust hydrolic roller Chevy zz4 intake 10185063 wiseco dish pistons forged scat rotating assembly 4.125 x 4.000 not sure what kind of power it's going to make but I bet it will be fun
Old Aug 22, 2018 | 11:27 AM
MrHorsepowerLSx's Avatar
11 Second Club
Sounds like alot of money being wasted to me, you could build an LS and swap it for less then that entire package and make more power. But should you feel to keep the Gen 1 motor in there, I’m sure it will be fun, no replacement for displacement
As for power I’m going to say around 500ish, that cam is very tame for a motor of that size
Old Aug 22, 2018 | 12:24 PM
Vortec350ss's Avatar
What are your goals with this combo? I'm sure it will be very fun.
I have never built a SBC myself, but I would make a few comments... this seems very much like a "truck" build. Compression isnt very high, heads and cam are relatively small. Those cubes will gobble up that cam like its stock. I would go bigger!
Old Aug 22, 2018 | 01:02 PM
terravast4's Avatar
thats a small cam for even a 350 sbc
Old Aug 22, 2018 | 02:12 PM
I don't have an exact powerlevel I'm shooting for I talked to crane they recommended this cam since it will be low and midrange power as well as be able to pass emissions (no visual here luckily) I've had an ls truck before but this being an old body style so I just want to keep the old sbc design could I go bigger than that on the cam and still pass? I am keeping egr and using dual high flow cats my state is Utah btw
Old Aug 22, 2018 | 02:25 PM
Do they have a sniffer? Tuning around an OBD emissions test is easy as pie. A few more degrees of duration and a 114 LSA would go a long way in making more HP up top.
Old Aug 22, 2018 | 02:27 PM
yup it's a sniffer test 95s to old to be obd2 and I'm using the holley sniper unit the only thing the tbi computer is gonna be used for is the transmission I wonder if I could get away with something along the lines of 220/226 114 lsa as I have alot of cubes would it still be good for lower end? The other one is what crane recommended for my application since it's a 4x4 daily driver etc
Old Aug 22, 2018 | 07:08 PM
MikeGyver's Avatar
....... A few more degrees of duration and a 114 LSA would go a long way in making more HP up top.
If you want to rev a 427 SBC. But maybe you're right, the cam in the first post would be peppy, but it would be a shame if it just went flat at maybe 4500.
Old Aug 22, 2018 | 09:10 PM
It's supposed to peak at midrange but It can go up to 5800 it's crane 109671 is the part number
Old Aug 22, 2018 | 10:28 PM
MikeGyver's Avatar
That pretty much confirms what I just said.
