383 or 355
Old Feb 22, 2012 | 01:33 PM
laoutlaw's Avatar
Default 383 or 355
I am going to be rebuilding the 350 in my 1997 C1500. I need help deciding on going with a 355 with the vortec heads that will have a 3 angle valve job done and bigger valves on the exhaust side. It will also have the work done to put a bigger cam in. Not sure what cam yet. I am also thinking of going 383 with the same heads and also not.sure what cam. Will the spider injection be good enough for the 383 and why cams do yall think I should put in either one.
Old Feb 22, 2012 | 04:08 PM
DR132's Avatar
What do you plan on doing with the truck? A 383 with some head work and a 280 advertised duration cam would be a decent street performance combo but you'd want a higher stall torque converter if you have an AT. It really depends on what you want to do with the truck
Old Feb 22, 2012 | 08:59 PM
laoutlaw's Avatar
I am planning on putting atleast a 3000 stall. I want a street/strip combo. I would like it to pull hard from mid range to top. Something to play around in the streets with the fellas from work and maybe a trip to the track every once in awhile.
Old Feb 22, 2012 | 09:06 PM
Mangled03gmc's Avatar
Baltimore Whore
The spider injection is not going to be enough for a healthy 355. If i were building one, I would go for the 383. The stuff is so cheap to build now days it is fullish not to.
Old Feb 22, 2012 | 09:57 PM
1994Vmax's Avatar
Or do a mild cammed 6 liter and skull drag most any 383 that could ever hope to live beneath that lovely CSFI system in those trucks.......
Old Feb 23, 2012 | 02:50 AM
DR132's Avatar
oh damn, missed the part about him sticking with the stock injection system, i skipped over that generation of chevy engine so i'm not sure what they're capable of...if it was mine i'd throw a carb on in and call it good
Old Feb 27, 2012 | 09:49 AM
laoutlaw's Avatar
Ok. I think that I am going with the 383. I want it to pull hard from mid to top. What cam do yall think would be best for it. Do I need to put bigger rockers like 1.6. I am going to do the 3 angle valve job and bigger exhaust valves in the heads so they are going to be off the truck to do the other work needed. Also what. Compression can I go up to. Looking to get the most out of.the spider injection system on the truck. I also upgraded the spider system a couple months ago. I am trying to get my truck into the low 14 to high 13 seconds in the quarter. Any help will be appreciated. Thanx
Old Feb 27, 2012 | 11:39 AM
1994Vmax's Avatar
For a site that actually will give you any real information on building up a Gen 1 Vortec go to the link below. This is an LS engine site, and most of us ( myself included) don't build up the old Vortec 350 trucks unless we are dumping the 350 into a trash dumpster.....
GM Performance :: Index
Old Feb 27, 2012 | 11:53 AM
laoutlaw's Avatar
Thanx for the site.
dirt track racer 81
Sep 21, 2015 06:44 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
ss4chad
Aug 15, 2015 02:25 AM
