2012
Old Dec 13, 2011 | 11:43 AM
Team Paulie's Avatar
Registered User
Default 2012
Delete this thread
Old Dec 13, 2011 | 12:57 PM
SweetS10V8's Avatar
You can get rid of it in the tune = void warranty
You can remove all the AFM parts as well for a perminate solution.
Old Dec 13, 2011 | 01:07 PM
Registered User
Do all the 2011+ have that standard on the 5.3's? Just heard some horror story's from my buddies at the shop with heads and what not issues.
Old Dec 13, 2011 | 04:13 PM
pasadenaman's Avatar
I think there is a DOD Delete kit out there for what your looking for. My '08 has the AFM and it takes a while to get used to it switching from 4 to 8cyl. It sounds like the trans is slipping when it switches with my exhaust.
Old Dec 13, 2011 | 09:57 PM
Unless you are going to do a cam swap it's best to leave it alone. They fail here and there but overall they are reliable. The early 07-08's were the worst years. You can disable it in the tune and it may or may not eradicate the problem simply because the lifter stays pumped up all the time.
The reason it sounds rampant on the board here and others is because we are a extremely small cross section of consumers who buy modify and run the pee whiney dog **** out of our rides. If theres a weak spot we are going to find it. Or as my dad said when I was younger and in my dukes of hazard general lee pedal car "boy you could tear up a steel ball bare handed.."
Old Dec 14, 2011 | 10:03 AM
Registered User
Roger that guys, gonna see if one or the other is still there come after the holidays, Then its game on..
Old Jan 9, 2012 | 05:07 PM
Registered User
I cant make my mind up on a new truck...
Old Jan 9, 2012 | 05:30 PM
Vortec350ss's Avatar
Where are you from? Do you need the 4x4?
Old Jan 10, 2012 | 08:01 AM
Larry's Avatar
Corvette & Mustang Moderator
My 2011 5.3 Silverado does not have AFM. If it does I experience none of the symptoms as described while driving. However, according to my tune file DOD is enabled.
Old Jan 10, 2012 | 05:20 PM
They all have AFM and VVT you can't get a 5.3 without it.
