2003 Sierra: Cuts off around turns, hard stops
I've done a search to no avail, apologize in advance if this is a frequent question. It's a 4.8L.
This has happened 4-5 times over the past two months. Either around a moderately fast turn or a sudden stop, the engine will just turn off. It quickly restarts when I pop it into neutral and turn the key. Doesn't seem to happen every time, and I can't "make" it happen when I try.
Thanks for the help.
This happened to me a while back. Everytime i attempted a youturn my truck died (and i lost power steering..).
I cleaned my TB and intake filter and also upgraded my alternator.
However my issues were caused by the load of my audio system so this may not apply to you.
I rarely drive below 1/2 tank, and this hasn't occurred when I was anywhere near low on fuel.
I thought about cleaning my TB, but it makes little sense as to why the TB would cause it to kill only on turns or sudden stops. And no, I have no aftermarket audio or strains on the alternator.
Mine has done it too. My idle is a little low and the extra strain on the power steering pump at lock or the sudden drop in rpm from a quick stop just causes it to die. I'm not really sure why it does it but i guess the idle needs to be bumped a bit.
