2003 Sierra: Cuts off around turns, hard stops
Old Nov 18, 2008 | 09:18 PM
LSUxBlake's Avatar
Default 2003 Sierra: Cuts off around turns, hard stops
I've done a search to no avail, apologize in advance if this is a frequent question. It's a 4.8L.
This has happened 4-5 times over the past two months. Either around a moderately fast turn or a sudden stop, the engine will just turn off. It quickly restarts when I pop it into neutral and turn the key. Doesn't seem to happen every time, and I can't "make" it happen when I try.
Thanks for the help.
Old Nov 19, 2008 | 02:52 AM
BassBaller5's Avatar
This happened to me a while back. Everytime i attempted a youturn my truck died (and i lost power steering..).
I cleaned my TB and intake filter and also upgraded my alternator.
However my issues were caused by the load of my audio system so this may not apply to you.
Old Nov 19, 2008 | 08:20 AM
chevrolet all the way's Avatar
dude of course your gonna lose power steering... your engine stopped turning. sorry i guess you had a brain fart lol
Old Nov 19, 2008 | 10:09 AM
thanks for pointing that out? I never realized that power steering required...power?
Old Nov 19, 2008 | 10:11 AM
BlackGMC's Avatar
Resident Retard
Have you noticed how much gas you have in the tank when this happens?
Old Nov 19, 2008 | 02:08 PM
95 bright teal's Avatar
If th tank is much less than a 1/4 full that can happen. not a good thing to do
Old Nov 19, 2008 | 06:41 PM
LSUxBlake's Avatar
I rarely drive below 1/2 tank, and this hasn't occurred when I was anywhere near low on fuel.
I thought about cleaning my TB, but it makes little sense as to why the TB would cause it to kill only on turns or sudden stops. And no, I have no aftermarket audio or strains on the alternator.
Old Nov 19, 2008 | 06:53 PM
StrokerAce03's Avatar
Mine has done it too. My idle is a little low and the extra strain on the power steering pump at lock or the sudden drop in rpm from a quick stop just causes it to die. I'm not really sure why it does it but i guess the idle needs to be bumped a bit.
Old Nov 19, 2008 | 06:55 PM
LSUxBlake's Avatar
Sounds like that may be it. The idle dips just low enough for a second to kill it. Maybe I can get a tune to clean that up.
Thanks for the replies btw.
Old Nov 19, 2008 | 06:56 PM
Our trucks have roll control that shuts the motor down if it thinks its going to roll
I have heard it happening to a few guys when they really slam on the brakes or doing donuts
