2/4 drop with 22x10's
Old Jan 7, 2007 | 12:48 AM
regency's Avatar
Default 2/4 drop with 22x10's
would this work!!! a buddy of mine has a rcsb 04 with a 2/4, which measures to be a 3/4.5 on stock wheels and he is wanting some 22's. Well he found some and there 22x10 with a 29" tire. Any rubbing issue?????
Old Jan 7, 2007 | 06:03 AM
2004SSS's Avatar
i know i have an ex cab im runnign a 2-3.5 drop with 22 x 10s and a 31 inch tire, i have no issues in the back it does run a little in the front but nothign bad at all. it does depend on tire and offset/backspacing. i know a 305/40/22 will be a good tire to go with.
Old Jan 7, 2007 | 10:10 PM
Allan21's Avatar
i have the 4,6 drop with 20's no rubbing issues
Old Jan 8, 2007 | 09:23 AM
You shouldn't have any rubbing issues as long as you have at least a +30 offset. That i my problem right now, I only have a +18 so I can't drop.
Old Jan 9, 2007 | 08:21 PM
regency's Avatar
well we got them on and had NO isses!!!! the tread was a little smaller than the width of the rim and were a little shorter than stock!
Old Jan 14, 2007 | 12:47 PM
D King's Avatar
I got an 03 Sierra with Panther 22x9.5 wrapped in KUHMO 305/45R22. I have only a 2 inch drop on the rear. The tires just barely scrub the plastic inner fender wells when turning all the way. But 2 or 3 times now i have hit dips in the road and the tires will catch the lip on the fender and pull it down and in the mean time it'll cut the outside of the tire. I would recommend going with an 8.5 inch rim. I got a friend with a 4/6 and on a 00 Sierra with 22x8.5 with a low profile tire, so either go will a smaller tire or an 8.5 rim.
USMCvet0311
Jan 16, 2016 06:04 PM
smok'nZ
Oct 6, 2015 01:14 PM
X_Racing1
Sep 30, 2015 01:59 AM
twake_410
Sep 25, 2015 10:09 PM
