00 silverado sas brake pedal spongy
Old Oct 4, 2015 | 07:06 PM
vipergtrdj's Avatar
Default 00 silverado sas brake pedal spongy
Recently finished a sas swap on my 2000 silverado. I Used a dana 60 front, sterling 10.25 rear, Using 85 k20 calipers front and rear.
New calipers, new hard lines, rubber lines. I removed the abs module, and ran the brake lines right to the master cylinder. Bench bled the master, and bled calipers. I get a solid stream of brake fluid, no air. I've done the two man brake bleeding, and get no air.
I've tried two masters, and two boosters, rechecked all fittinga. When I unhook the vacuum line from the booster the pedal is rock hard, but with the vacuum line hooked up it drops to the floor. I'm at a lost, what is going on with the brakes?
Old Oct 4, 2015 | 07:18 PM
GMCtrk's Avatar
Vacuum booster is a pos and doesn't belong on a truck. A hydroboost swap would be inexpensive and yield very good results
Old Oct 4, 2015 | 07:26 PM
vipergtrdj's Avatar
That's happening in about a month or so, but I'd like to have brakes before then.
Old Oct 4, 2015 | 07:41 PM
George C....'s Avatar
Formerly ScreamingL
Booster may of **** the bed
Old Oct 4, 2015 | 11:21 PM
Wolftrk99's Avatar
Sounds like time to swap to hydroboost.....
Old Oct 7, 2015 | 06:52 PM
vipergtrdj's Avatar
Just finished swapping to hydroboost. Cost a whole $120 for everything. $60 for hydroboost, master cylinder and brake pedal. $30 for pressure lines. $20-30 for misc fittings, hoses, clamps, fluids.
Best upgrade I've ever done, wish I did it sooner !
My only concern is, does it put more strain on the power steering pump? If so what's a good upgrade for a new pump ?
Old Oct 7, 2015 | 07:04 PM
GMCtrk's Avatar
Nope, pump is fine. Only difference should be the fittings.
Old Oct 7, 2015 | 08:20 PM
Wolftrk99's Avatar
Maybe upgrade the spool valve??...
Blwn99x
Mar 24, 2023 11:14 AM
Bigblu
Oct 3, 2015 09:55 PM
Bigblu
Oct 3, 2015 07:58 PM
X_Racing1
Sep 30, 2015 01:59 AM
GM1697
Sep 28, 2015 08:28 PM
