FS: SSR intake manifold complete w/UMI 90mm TB & return style fuel rails
Old May 15, 2008 | 03:43 PM
thunder550's Avatar
High on diesel fumes
Default FS: SSR intake manifold complete w/UMI 90mm TB & return style fuel rails
I'm going to a carb style intake manifold and don't need this anymore. This manifold is set up for a cable throttle body truck and a return style fuel system.
Includes:
SSR 90mm manifold
Stock MAP sensor
UMI 90mm throttle body with IAC motor and TPS
My homemade throttle cable bracket w/hold-down for MAP sensor
Homemade fuel rail clamps
Stock truck fuel rails and crossover
Vortec engine cover (slotted for throttle cables) & bracket/bolts
Full set of intake manifold bolts (a couple of the rubber bushings are messed up but they still work fine)
My used intake manifold gaskets - I'm sure that they are reusable.
I only have about 25k miles on this whole setup.
The fuel rails are set up for the taller LS1 style injectors. This will not work with truck style injectors...they are too short and the crossover will not clear. If you want to run truck injectors, you'll have to go with another fuel rail setup.
The only issue I ran into was that I cracked the fitting on the vacuum port on top of the manifold by the crossover. I put some JB Weld on it to seal it up and it has been fine ever since.
$280 for intake manifold w/bolts & engine cover
$575 for throttle body w/sensors
$20 for throttle bracket/MAP hold-down
$30 for fuel rails and my homemade mounts/bolts
$875 takes it all
Shipping included in prices above.
Here's some pics when I was putting the thing together brand new (the injectors in the pics below are NOT included)
Here are some recent pics of this installed on my truck. You can see how the brackets, cover bolts, and MAP sensor hold down are situated.
Here's a couple of fairly recent engine bay pics, so you can see what the engine cover looks like.
Old May 15, 2008 | 04:33 PM
ZZebes's Avatar
Bump for a good seller
Old May 15, 2008 | 05:35 PM
350SS's Avatar
x2
Old May 15, 2008 | 05:53 PM
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by 350SS
x2
x3
Dustin
Old May 15, 2008 | 11:40 PM
thunder550's Avatar
Thanks fellas
Old May 16, 2008 | 01:52 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Chris I want the UMI T/B. Bump for a great guy to deal with.
Old May 18, 2008 | 06:42 PM
thunder550's Avatar
Bump...
AJ I'll let you know if I decide to part it out.
Old May 27, 2008 | 12:15 AM
thunder550's Avatar
Willing to part out...also dropping price for full set
$875 takes it all
OHsixLS3
Dec 27, 2016 09:30 AM
GMCtrk
Jul 17, 2015 06:39 PM
Deceptarado
Jul 8, 2015 05:24 PM
Black-Syde
Jul 6, 2015 02:12 PM
