FS: 6.0 LQ4/LS2 aluminum block
Old Apr 8, 2008 | 07:12 PM
67SS509's Avatar
10 Second Truck Club
Default FS: 6.0 LQ4/LS2 aluminum block
I have an assembled brand new LS2 block with a LQ4 crank, rods, pistons and stock LQ9 cam. The rotating assembly has less than a 100 miles on it. It was a warranty takeout that had a cracked block. It has all the conversion pieces for installation into anything with the 24 reluctor crank. The heads are 862 castings with 2.00" intake valves and 1.55" exhaust valves installed (6.0 valves) and ports cleaned up by hand. Final compression ratio is 10 to 1. All clearances and torques per factory specs. Can ship...email with zip for quote.
Price...$2,850 + shipping....it's crated up and ready to ship!
New parts include:
LS2 block
Gaskets & seals
Valley cover
Timing chain cover
LS6 oil pump
LS2 timing gear set
Clevite rod bearings
Sealed Power plasma-moly rings
LS2 chain dampner
LS2 lifter guides
Coolant & oil galley plugs
LS7 lifters
LS2 MLS head gaskets
GM valve seals
LS6 valve springs
GM head bolts
Old Apr 9, 2008 | 06:57 PM
67SS509's Avatar
Bump for today!
6.0l RST
Nov 23, 2015 11:30 AM
mikeyjm1
17
Oct 29, 2015 11:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
chvy=power
Sep 8, 2015 11:06 AM
