ASM headers - Magnaflow X and !Cat pipes
Old May 18, 2005 | 12:05 AM
BigTex's Avatar
Default ASM headers - Magnaflow X and !Cat pipes
ASM headers - modified with the BigTex touch. Collector has been expanded to 3" from the standard 2.5" collector. These have AIR and EGR provisions, but have blockoff plates over them currently. Have about 8K miles on them. Currently setup with a 3-bolt flange. Finish is good with no rust. $525 shipped.
Also have front pipes made to fit those headers. Pipes are 3" in diameter and contain no converters. Pipes merge into a Magnaflow X pipe just past the transmission crossmember. Just create your own true dual catback. X pipe has about 500 miles on it. $150 additional for the buyer of the headers.
Old May 18, 2005 | 06:04 PM
Crazy's Avatar
Could you do $400?
Old May 18, 2005 | 07:49 PM
BigTex's Avatar
Nope, sorry.
Old May 18, 2005 | 08:46 PM
Crazy's Avatar
I live in Mesquite, what could you do unshipped??
Old May 18, 2005 | 09:49 PM
greentahoe's Avatar
would those bolt up to my Tahoe Thorleys?? They are a mid length. I was thinking of running 3" pipe from the headers to the X pipe and then maybe to a 2 into 1 magnafow. I'd have 2 electric cutouts welded in after the X. Im curious if this will flow enough air for my setup.
Old May 18, 2005 | 10:06 PM
BigTex's Avatar
I doubt that it would be a perfect fit for the Throley headers. The exhaust pipes were built for these modded headers. Your description is nearly identical to my config. I've got dual 3" pipes after the X going into a dual 3" in / single 4" out magnaflow muffler. It should handle your setup.
Old May 18, 2005 | 10:14 PM
BigTex's Avatar
Crazy - I'll tell you what, I live in Forney, so I'm close. You buy my headers and 224 cam for $750 cash, and I'll personally custom tune your truck with my wideband and flashscan for $100 when you get them installed.
Old May 24, 2005 | 08:38 PM
04Z71SATX's Avatar
Can you tune my 04?
Old May 25, 2005 | 11:52 AM
pacebria's Avatar
Default ?
Will these bolt on my 05 HD 2500 4x4. If So i have cash asap
Old May 25, 2005 | 03:39 PM
BigTex's Avatar
Yes, they will bolt up to a 2005 HD perfectly. You will need some exhaust work done to connect whatever muffler you plan on running to the system. Actually, with the larger diameter HD front pipes, you probably only need the headers and not my front 3" pipes.
GXPJAY
Feb 13, 2022 08:15 AM
MS79
Aug 29, 2015 12:24 AM
06 4.8
Aug 19, 2015 08:57 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
