zero oil pressure.......sh!t
Old Jan 5, 2009 | 09:47 PM
EVILGMC's Avatar
Default zero oil pressure.......****
the gauge does not move when i first start it up. shows normal numbers after a few minutes. dont hear any bad noises, no drips, etc. going to test pressure tomorrow @ the oil filter connection. hopefully just a sending unit. anyone experienced this?
Old Jan 5, 2009 | 09:50 PM
RandomHero's Avatar
Did it do it just suddenly or was this after a cam swap? Were there any kind of symptoms before it occured?
Old Jan 5, 2009 | 09:52 PM
53RUSSELL's Avatar
Did check against EFLIve or Hptuner to see if it shows any pressure?? If show 0 on the software than it the sending unit.
Old Jan 5, 2009 | 10:13 PM
EVILGMC's Avatar
was out on a cruise for most of the day...beat on it, but no more than i always do. pulled into the gas station to fill before putting her away and when i started back up...gauge at 0 and the low pressure waning on the DIC.
only change in the past week was swapping my vette TAC/pigtail for an x-link. already had the 90mm. cam has been in for 6 months. i am gonna plug in with a TECH2 tomorrow and also a manual pressure gauge that spins on where the oil filter mounts. i am hoping its the sender.....but how the gauge shows pressure after a mile or so is strange.
maybe the oil pump is being stubborn, maybe a bearing, maybe a sender. damn senders are a pain in the *** to get to, especially with the radix...well, easier than a new bottom end. or maybe an excuse to go 402?
Old Jan 5, 2009 | 10:15 PM
RandomHero's Avatar
Well there's not really a ton of stuff that can go wrong inside an oil pump. I had the pickup tube o-ring go bad(A nightmare for Cody and Me).
Possible things it could be:
O-ring on oil pump(most likely)
oil pump bad
sender bad
Cam bearing bad
I'll think of more theories if they should arise in my head.
Old Jan 5, 2009 | 10:23 PM
EVILGMC's Avatar
last time i had oil issues ended up being a bent crank and pounded out main bearings. oops.
Old Jan 7, 2009 | 10:11 PM
EVILGMC's Avatar
took it to perform the pressure test and the gauge wont malfunction.... maybe a bad sender. im gonna leave it...whats the worst that can happen. hahahaha
Old Jan 8, 2009 | 11:53 AM
thunder550's Avatar
High on diesel fumes
I had the same kind of thing happen. Turns out a tiny piece of debris got stuck in the pressure relief valve and hung it open. Replaced the pump and all fixed. Don't run your engine for more than a few seconds at a time until you figure out what the problem is.
Old Jan 9, 2009 | 08:27 AM
EVILGMC's Avatar
im tearing it down soon. oh how much fun!
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
69z-28
Sep 21, 2015 07:31 AM
Velocity1
Sep 15, 2015 11:29 PM
