Z06 cam in 6.0
Old Aug 26, 2003 | 01:47 PM
StreetSweepa's Avatar
Default Z06 cam in 6.0
What kind of power gains will you get with the z06 cam in the 6.0 engine?
Old Aug 26, 2003 | 02:15 PM
onyx's Avatar
14 Second Truck Club
Default Re: Z06 cam in 6.0
or the 5.3 for that matter...
Old Aug 26, 2003 | 04:25 PM
Hit Man X's Avatar
If you do use this cam, I'd advance it 4* when installing. I remember it has like 2* retard built it so this would give you a 2* advance total.
That'd probably help get the powerband back down a bunch too.
Oh maybe 20rwhp? Depends on if ya got headers, correct springs, etc
Old Aug 26, 2003 | 06:06 PM
with some headwork it should give you good numbers.
Also i think the cam has 2* advance ground into it not retard
Old Aug 26, 2003 | 07:00 PM
Hit Man X's Avatar
I could swear it is 2* retarded as the cam pulls to 6500rpms at a 204 intake dur. Retarding the cam raises the power band, advancing brings it down
Old Aug 26, 2003 | 09:10 PM
blemoine02's Avatar
how do you advance the timing
Old Aug 26, 2003 | 11:10 PM
BigTex's Avatar
I'm pretty sure that both LS6 cams are retarded 2 degrees.
Install an adjustable timing chain to advance the cam. Rollermaster chains allow you to advance or retard in 2 degree increments, while most other chains go are in 4 degree increments.
Old Aug 27, 2003 | 01:41 PM
sorry i got it backwards
Old Aug 27, 2003 | 05:58 PM
Hit Man X's Avatar
No problems, if I was wrong (which I am and can be) I'd admit it. I am always up for learning more and expanding my mind.
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
lxcoupe
Jul 30, 2015 02:42 PM
steves86ta
Jul 28, 2015 10:21 AM
