You think my CAI is a restriction?
Old Aug 29, 2011 | 08:00 AM
brandon6.0's Avatar
Default You think my CAI is a restriction?
Hey guys, i was wondering what u thought of my cai. Its a K&N fipk kit for the 2000 model chevrolets. It been a great kit without any problems. I also relocated the iat sensor closer to the throttle bodie inside the tube. Now, the other day i was out messin with the truck and noticed that the tube outlet diameter is the same size as the inside of my 90/92mm throttle bodie. I am runnin the tbss intake also. Now, do u guys think there is any gain to be had by making my own 4" cai? I checked it out and a 4" pvc inside diameter will fit over the 90mm throttle bodie mouth. I know this has got to help something. What do u all think?
Old Aug 29, 2011 | 08:15 AM
Rhino79's Avatar
9 Second Club
My truck was an 09 (tbss style), I ran a 4" setup. It helped for sure, I kept the stock box and gutted the bottom and fender inlet to help flow into the box. I think it'd be a good choice since your induction is larger now.
Old Aug 29, 2011 | 08:25 AM
ak2007r6's Avatar
Couldn't hurt to try. I have the stock air box with a K&N filter and then made my own tube out of 4" PVC and a couple rubber couplings and could tell the difference right away when I went for a drive.
It's $40 bucks at Home Depot so not like you would loose much trying it out.
Old Aug 29, 2011 | 09:48 AM
2007chevy5.3l's Avatar
I have the same type k&n intake and have thought about trying a 4in setup. If i ever do i will log some before and after runs to see if any difference is made
Old Aug 29, 2011 | 09:57 AM
Lil brother PI's Avatar
should work
Old Aug 29, 2011 | 10:05 AM
ak2007r6's Avatar
I wasn't able to compare HP numbers on a dyno or anything but I could tell a different in throttle response just by the seat of my pants. I also saw a few MPG increase when using cruise control on the HWY
Will get with AKlowriderZ71 once I get my wide band installed and have him really fine tune it for me and see what difference that makes for it
Old Aug 29, 2011 | 10:10 AM
Glad to hear someone is already on top of it. By any chance do you have any pics of your intake?
Old Aug 29, 2011 | 10:33 AM
ak2007r6's Avatar
It's a few dirty *** pic from when installing it, but yea. I detailed the truck up really good a few days after I installed it and forgot to snap a pic of the engine
This was while I was still fitting it up so not all the bands are on and I didn't tap it for the breather hose yet.
Fitting it up / test fitting.
I feel like a noob for not paying closer attention. I drilled the hole for the breather hose and fitting and put it on the wrong side. It should have been on the other side facing the motor. Oh well I was still going to clean it up and make it look prettier once home. Might just redo it and put the hose on the other side. I don't think there is any performance issue or anything with how the hose is now, just looks odd.
Old Aug 29, 2011 | 10:48 AM
Don't look bad at all! So what's all needed? Just a bend pipe, a straight and 2 couplers?
Old Aug 29, 2011 | 10:54 AM
ak2007r6's Avatar
2 feet of 4" PVC, a 4" PVC street elbow, two rubber couplings, a couple feet of 1/4" vinyl tubing and a couple 1/4" hose clamps and a fitting to put in place for the breather hose (I have part number written down somewhere.)
I figured there would be a write up on this forum for it but if there is not I can type one up. It really is very simple, took me 20-30 minutes tops and is a noticeable difference. The only thing I had to do different is in all the threads I read they were using 4" rubber couplings for their connections and I have to get a 4" to 3.5" reducer to fit mine. Not sure why mine was a little smaller (you think the 6.2 would have a bigger one than a 4.8 or 5.3).
