Yet another 4.8 to 6.o question
Old Feb 18, 2013 | 11:45 AM
BillyM151's Avatar
Registered User
Default Yet another 4.8 to 6.o question
I have a 1999 RCSB with a 4.8 and original nv3500 5 speed. I'm looking to do an lq9 swap later this year. My question is since the donor engine will be coming out of a truck with an automatic transmission and mine is factory manual will is cause any problems or extra work for the wiring harness or anything else? I know most say the swap is "plug and play" but the 1999 5 speed manual is kind of an odd year and combo so I figured there may be some more obsticles I run into than others. Thanks for any guidance.
Old Feb 18, 2013 | 12:11 PM
TXSZ66AVLANCHE's Avatar
Use your intake manifold, flywheel, and clutch on the 6.0, boom problem solved.
Old Feb 18, 2013 | 01:35 PM
AJK381's Avatar
You will need to install a pilot bearing too.
Old Feb 18, 2013 | 04:15 PM
bgray's Avatar
TOTM: June 2007
Direct swap still. Consider doing Clutch/flywheel combo......youll be right there
Old Feb 18, 2013 | 04:27 PM
That transmission will hate the 6.0, or you will hate the 6.0 getrag combo....then you can upgrade to a T56!
Old Feb 18, 2013 | 04:30 PM
nonnieselman's Avatar
yea dont worry about the automatic harness.. sell that.
just plug everything up to the 6.0 and go.
Old Feb 19, 2013 | 02:13 PM
BillyM151's Avatar
Registered User
Thanks a ton. Sounds like it won't be too much of a headache. T56 will definitely be coming in the future. I'll just have to baby the nv3500 until I get the funds.
Old Feb 19, 2013 | 02:58 PM
bgray's Avatar
TOTM: June 2007
NVM handle power just fine. Just don't try shifting it fast and bend the clutch fork
Old Feb 19, 2013 | 04:18 PM
BillyM151's Avatar
Registered User
If I'm using the same flywheel and clutch will I still need a new pilot bearing?
Old Feb 19, 2013 | 04:30 PM
Yes, the pilot bearing goes into the crankshaft.
